Time Before: 0.00215 seconds
Time After: 0.00284 seconds
Time Taken: 0.00069 seconds
Time Before: 0.00293 seconds
Time After: 0.00344 seconds
Time Before: 0.00373 seconds
Time After: 0.00389 seconds
Time Before: 0.00469 seconds
Time After: 0.00714 seconds
Time Taken: 0.00245 seconds
Time Before: 0.00396 seconds
Time After: 0.01211 seconds
Time Taken: 0.00815 seconds
Time Before: 0.01445 seconds
Time After: 0.01488 seconds
Time Before: 0.01761 seconds
Time After: 0.01888 seconds
Time Before: 0.01373 seconds
Time After: 0.01913 seconds
Time Taken: 0.00539 seconds
Time Before: 0.02667 seconds
Time After: 0.02683 seconds
Time Before: 0.02913 seconds
Time After: 0.03042 seconds
End call of global.php: 0.032961845397949
Time Before: 0.03421 seconds
Time After: 0.03439 seconds
Time Before: 0.03639 seconds
Time After: 0.03792 seconds
Time Taken: 0.00153 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=129968', badlocation = 1
Time Before: 0.05274 seconds
Time After: 0.05295 seconds
Memory Before: 4,288.977 KB
Memory After: 4,289.203 KB
Page generated in 0.051823854446411 seconds with 9 queries, spending 0.0081820487976074 doing MySQL queries and 0.043641805648804 doing PHP things.
