Time Before: 0.01882 seconds
Time After: 0.02682 seconds
Time Taken: 0.00800 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.02692 seconds
Time After: 0.02736 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.02760 seconds
Time After: 0.02775 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.02850 seconds
Time After: 0.03140 seconds
Time Taken: 0.00290 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.02782 seconds
Time After: 0.03550 seconds
Time Taken: 0.00767 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.04488 seconds
Time After: 0.04522 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.04764 seconds
Time After: 0.04890 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.04395 seconds
Time After: 0.04910 seconds
Time Taken: 0.00514 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.08989 seconds
Time After: 0.09008 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.13309 seconds
Time After: 0.13439 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
End call of global.php: 0.13637804985046
Time Before: 0.15860 seconds
Time After: 0.15878 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.16352 seconds
Time After: 0.16565 seconds
Time Taken: 0.00213 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
SET lastactivity = 1773381760, location = '/forums/private.php?do=newpm&explain=1&u=129973', badlocation = 1
WHERE sessionhash = 'e0f0ca8e3048a6e309b58c7aba652665'
Time Before: 0.19350 seconds
Time After: 0.19391 seconds
Memory Before: 5,998.219 KB
Memory After: 5,998.430 KB
Page generated in 0.19244599342346 seconds with 9 queries, spending 0.0093016624450684 doing MySQL queries and 0.18314433097839 doing PHP things.
