Time Before: 0.00142 seconds
Time After: 0.00194 seconds
Time Before: 0.00202 seconds
Time After: 0.00264 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00295 seconds
Time After: 0.00312 seconds
Time Before: 0.00380 seconds
Time After: 0.00611 seconds
Time Taken: 0.00230 seconds
Time Before: 0.00319 seconds
Time After: 0.00948 seconds
Time Taken: 0.00629 seconds
Time Before: 0.01141 seconds
Time After: 0.01176 seconds
Time Before: 0.01414 seconds
Time After: 0.01538 seconds
Time Before: 0.01085 seconds
Time After: 0.01554 seconds
Time Taken: 0.00469 seconds
Time Before: 0.02074 seconds
Time After: 0.02092 seconds
Time Before: 0.02307 seconds
Time After: 0.02537 seconds
End call of global.php: 0.027109861373901
Time Before: 0.02842 seconds
Time After: 0.02855 seconds
Time Before: 0.03050 seconds
Time After: 0.03190 seconds
Time Taken: 0.00140 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=130025'
Time Before: 0.04414 seconds
Time After: 0.04443 seconds
Page generated in 0.043253898620605 seconds with 9 queries, spending 0.0089688301086426 doing MySQL queries and 0.034285068511963 doing PHP things.
