Time Before: 0.00275 seconds
Time After: 0.00374 seconds
Time Taken: 0.00099 seconds
Time Before: 0.00382 seconds
Time After: 0.00456 seconds
Time Taken: 0.00074 seconds
Time Before: 0.00484 seconds
Time After: 0.00499 seconds
Time Before: 0.00604 seconds
Time After: 0.00866 seconds
Time Taken: 0.00262 seconds
Time Before: 0.00507 seconds
Time After: 0.01292 seconds
Time Taken: 0.00785 seconds
Time Before: 0.01477 seconds
Time After: 0.01517 seconds
Time Before: 0.01825 seconds
Time After: 0.01953 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01415 seconds
Time After: 0.01970 seconds
Time Taken: 0.00555 seconds
Memory After: 2,261.703 KB
Time Before: 0.02692 seconds
Time After: 0.02706 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02989 seconds
Time After: 0.03126 seconds
Time Taken: 0.00137 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.032883882522583
Time Before: 0.03435 seconds
Time After: 0.03449 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03655 seconds
Time After: 0.03798 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=130037', badlocation = 1
Time Before: 0.05045 seconds
Time After: 0.05090 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
Page generated in 0.049515962600708 seconds with 9 queries, spending 0.0087220668792725 doing MySQL queries and 0.040793895721436 doing PHP things.
