Time Before: 0.01045 seconds
Time After: 0.01366 seconds
Time Taken: 0.00322 seconds
Time Before: 0.01375 seconds
Time After: 0.01417 seconds
Time Before: 0.01440 seconds
Time After: 0.01453 seconds
Time Before: 0.01543 seconds
Time After: 0.01790 seconds
Time Taken: 0.00247 seconds
Time Before: 0.01460 seconds
Time After: 0.02311 seconds
Time Taken: 0.00851 seconds
Time Before: 0.02743 seconds
Time After: 0.02785 seconds
Time Before: 0.03112 seconds
Time After: 0.03233 seconds
Time Before: 0.02667 seconds
Time After: 0.03253 seconds
Time Taken: 0.00586 seconds
Time Before: 0.04851 seconds
Time After: 0.04868 seconds
Time Before: 0.05747 seconds
Time After: 0.05873 seconds
Time Before: 0.06446 seconds
Time After: 0.06465 seconds
Time Before: 0.06765 seconds
Time After: 0.06910 seconds
UPDATE session SET lastactivity = 1776743735, location = '/forums/private.php?do=newpm&explain=1&u=130056', badlocation = 1 WHERE sessionhash = '84d505ff74940a4d05f0ae95a61eba7a'
Time Before: 0.08941 seconds
Time After: 0.08972 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
