Time Before: 0.00339 seconds
Time After: 0.00477 seconds
Time Taken: 0.00138 seconds
Time Before: 0.00484 seconds
Time After: 0.00518 seconds
Time Before: 0.00538 seconds
Time After: 0.00549 seconds
Time Before: 0.00620 seconds
Time After: 0.01003 seconds
Time Taken: 0.00384 seconds
Time Before: 0.00554 seconds
Time After: 0.01349 seconds
Time Taken: 0.00796 seconds
Time Before: 0.01648 seconds
Time After: 0.01691 seconds
Time Before: 0.01941 seconds
Time After: 0.02059 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01568 seconds
Time After: 0.02079 seconds
Time Taken: 0.00512 seconds
Time Before: 0.02957 seconds
Time After: 0.02970 seconds
Time Before: 0.03315 seconds
Time After: 0.03453 seconds
End call of global.php: 0.037222146987915
Time Before: 0.03876 seconds
Time After: 0.03895 seconds
Time Before: 0.04198 seconds
Time After: 0.04345 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=130060', badlocation = 1
WHERE sessionhash = 'aed90e65d11e22ea884774a0c30a33f2'
Time Before: 0.05916 seconds
Time After: 0.05946 seconds
Memory Before: 4,911.867 KB
Memory After: 4,912.094 KB
Page generated in 0.058228015899658 seconds with 9 queries, spending 0.0093841552734375 doing MySQL queries and 0.048843860626221 doing PHP things.
