Time Before: 0.02748 seconds
Time After: 0.03532 seconds
Time Taken: 0.00783 seconds
Time Before: 0.03544 seconds
Time After: 0.03584 seconds
Time Before: 0.03609 seconds
Time After: 0.03622 seconds
Time Before: 0.03712 seconds
Time After: 0.03977 seconds
Time Taken: 0.00265 seconds
Time Before: 0.03630 seconds
Time After: 0.04416 seconds
Time Taken: 0.00786 seconds
Time Before: 0.05204 seconds
Time After: 0.05245 seconds
Time Before: 0.05499 seconds
Time After: 0.05619 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.05136 seconds
Time After: 0.05646 seconds
Time Taken: 0.00510 seconds
Memory After: 2,261.820 KB
Time Before: 0.09826 seconds
Time After: 0.09846 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.11951 seconds
Time After: 0.12077 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.13241 seconds
Time After: 0.13255 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.13508 seconds
Time After: 0.13658 seconds
Time Taken: 0.00150 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1788973185, location = '/forums/private.php?do=newpm&explain=1&u=130086' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.15946 seconds
Time After: 0.15985 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
