Time Before: 0.02867 seconds
Time After: 0.03461 seconds
Time Taken: 0.00595 seconds
Time Before: 0.03471 seconds
Time After: 0.03525 seconds
Time Taken: 0.00055 seconds
Time Before: 0.03554 seconds
Time After: 0.03566 seconds
Time Before: 0.03642 seconds
Time After: 0.03916 seconds
Time Taken: 0.00274 seconds
Time Before: 0.03572 seconds
Time After: 0.04361 seconds
Time Taken: 0.00789 seconds
Time Before: 0.05463 seconds
Time After: 0.05484 seconds
Time Before: 0.05670 seconds
Time After: 0.05796 seconds
Time Before: 0.05385 seconds
Time After: 0.05819 seconds
Time Taken: 0.00434 seconds
Time Before: 0.09788 seconds
Time After: 0.09801 seconds
Time Before: 0.11495 seconds
Time After: 0.11620 seconds
Time Before: 0.12559 seconds
Time After: 0.12578 seconds
Time Before: 0.12838 seconds
Time After: 0.13004 seconds
Time Taken: 0.00166 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=130200' WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.14828 seconds
Time After: 0.14860 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
