Time Before: 0.00140 seconds
Time After: 0.00189 seconds
Time Before: 0.00196 seconds
Time After: 0.00279 seconds
Time Taken: 0.00083 seconds
Time Before: 0.00304 seconds
Time After: 0.00320 seconds
Time Before: 0.00397 seconds
Time After: 0.00737 seconds
Time Taken: 0.00340 seconds
Time Before: 0.00328 seconds
Time After: 0.01080 seconds
Time Taken: 0.00752 seconds
Time Before: 0.01286 seconds
Time After: 0.01328 seconds
Time Before: 0.01475 seconds
Time After: 0.01743 seconds
Time Taken: 0.00267 seconds
Time Before: 0.01223 seconds
Time After: 0.01772 seconds
Time Taken: 0.00549 seconds
Time Before: 0.02464 seconds
Time After: 0.02482 seconds
Time Before: 0.02684 seconds
Time After: 0.02806 seconds
End call of global.php: 0.029778957366943
Time Before: 0.03098 seconds
Time After: 0.03113 seconds
Time Before: 0.03329 seconds
Time After: 0.03531 seconds
Time Taken: 0.00202 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=130216', badlocation = 1
WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.05208 seconds
Time After: 0.05238 seconds
Page generated in 0.050721883773804 seconds with 9 queries, spending 0.0113525390625 doing MySQL queries and 0.039369344711304 doing PHP things.
