Time Before: 0.00215 seconds
Time After: 0.00274 seconds
Time Taken: 0.00059 seconds
Memory Before: 1,157.773 KB
Memory After: 1,182.891 KB
Time Before: 0.00280 seconds
Time After: 0.00321 seconds
Memory Before: 1,182.828 KB
Memory After: 1,183.836 KB
Time Before: 0.00343 seconds
Time After: 0.00357 seconds
Memory Before: 1,184.422 KB
Memory After: 1,184.945 KB
Time Before: 0.00409 seconds
Time After: 0.00663 seconds
Time Taken: 0.00254 seconds
Memory Before: 1,187.547 KB
Memory After: 1,188.469 KB
Time Before: 0.00362 seconds
Time After: 0.01017 seconds
Time Taken: 0.00655 seconds
Memory Before: 1,184.164 KB
Memory After: 2,265.195 KB
Time Before: 0.01204 seconds
Time After: 0.01233 seconds
Memory Before: 2,758.008 KB
Memory After: 2,758.625 KB
Time Before: 0.01349 seconds
Time After: 0.01516 seconds
Time Taken: 0.00167 seconds
Memory Before: 2,770.063 KB
Memory After: 2,769.922 KB
Time Before: 0.01141 seconds
Time After: 0.01536 seconds
Time Taken: 0.00395 seconds
Memory Before: 2,750.156 KB
Memory After: 2,883.281 KB
Memory Used: 133.125 KB
Time Before: 0.02078 seconds
Time After: 0.02091 seconds
Memory Before: 3,436.383 KB
Memory After: 3,436.898 KB
Time Before: 0.02311 seconds
Time After: 0.02435 seconds
Memory Before: 3,524.180 KB
Memory After: 3,524.773 KB
End call of global.php: 0.026506900787354
Time Before: 0.02810 seconds
Time After: 0.02840 seconds
Memory Before: 4,162.102 KB
Memory After: 4,162.531 KB
Time Before: 0.03133 seconds
Time After: 0.03278 seconds
Memory Before: 4,443.641 KB
Memory After: 4,445.328 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=130280'
Time Before: 0.04834 seconds
Time After: 0.04866 seconds
Memory Before: 4,921.742 KB
Memory After: 4,921.961 KB
Page generated in 0.047453880310059 seconds with 9 queries, spending 0.0084719657897949 doing MySQL queries and 0.038981914520264 doing PHP things.
