Time Before: 0.00227 seconds
Time After: 0.00306 seconds
Time Taken: 0.00079 seconds
Time Before: 0.00313 seconds
Time After: 0.00358 seconds
Time Before: 0.00380 seconds
Time After: 0.00401 seconds
Time Before: 0.00486 seconds
Time After: 0.00749 seconds
Time Taken: 0.00264 seconds
Time Before: 0.00408 seconds
Time After: 0.01104 seconds
Time Taken: 0.00696 seconds
Time Before: 0.01371 seconds
Time After: 0.01408 seconds
Time Before: 0.01671 seconds
Time After: 0.01836 seconds
Time Taken: 0.00165 seconds
Time Before: 0.01308 seconds
Time After: 0.01860 seconds
Time Taken: 0.00553 seconds
Time Before: 0.02664 seconds
Time After: 0.02682 seconds
Time Before: 0.02981 seconds
Time After: 0.03126 seconds
Time Before: 0.03578 seconds
Time After: 0.03606 seconds
Time Before: 0.03934 seconds
Time After: 0.04079 seconds
UPDATE session SET lastactivity = 1789052542, location = '/forums/private.php?do=newpm&explain=1&u=130288' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.05560 seconds
Time After: 0.05581 seconds
