Time Before: 0.00141 seconds
Time After: 0.00195 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00203 seconds
Time After: 0.00240 seconds
Time Before: 0.00267 seconds
Time After: 0.00283 seconds
Time Before: 0.00351 seconds
Time After: 0.00589 seconds
Time Taken: 0.00237 seconds
Time Before: 0.00288 seconds
Time After: 0.01088 seconds
Time Taken: 0.00800 seconds
Time Before: 0.01311 seconds
Time After: 0.01354 seconds
Time Before: 0.01600 seconds
Time After: 0.01719 seconds
Time Before: 0.01243 seconds
Time After: 0.01745 seconds
Time Taken: 0.00502 seconds
Time Before: 0.02455 seconds
Time After: 0.02470 seconds
Time Before: 0.02640 seconds
Time After: 0.02771 seconds
Time Taken: 0.00132 seconds
Time Before: 0.03056 seconds
Time After: 0.03073 seconds
Time Before: 0.03278 seconds
Time After: 0.03418 seconds
Time Taken: 0.00140 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=130295' WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.04694 seconds
Time After: 0.04719 seconds
