Time Before: 0.01778 seconds
Time After: 0.03252 seconds
Time Taken: 0.01474 seconds
Time Before: 0.03260 seconds
Time After: 0.03297 seconds
Time Before: 0.03316 seconds
Time After: 0.03331 seconds
Time Before: 0.03419 seconds
Time After: 0.03697 seconds
Time Taken: 0.00279 seconds
Time Before: 0.03339 seconds
Time After: 0.04107 seconds
Time Taken: 0.00768 seconds
Time Before: 0.05262 seconds
Time After: 0.05309 seconds
Time Before: 0.05566 seconds
Time After: 0.05688 seconds
Time Before: 0.05192 seconds
Time After: 0.05708 seconds
Time Taken: 0.00517 seconds
Time Before: 0.09464 seconds
Time After: 0.09480 seconds
Time Before: 0.11108 seconds
Time After: 0.11230 seconds
End call of global.php: 0.114501953125
Time Before: 0.12213 seconds
Time After: 0.12235 seconds
Time Before: 0.12534 seconds
Time After: 0.12677 seconds
SET lastactivity = 1783067952, location = '/forums/private.php?do=newpm&explain=1&u=130314', badlocation = 1
Time Before: 0.14645 seconds
Time After: 0.14675 seconds
Page generated in 0.14548683166504 seconds with 9 queries, spending 0.0083081722259521 doing MySQL queries and 0.13717865943909 doing PHP things.
