Time Before: 0.00191 seconds
Time After: 0.00255 seconds
Time Taken: 0.00064 seconds
Time Before: 0.00265 seconds
Time After: 0.00316 seconds
Time Before: 0.00344 seconds
Time After: 0.00358 seconds
Time Before: 0.00451 seconds
Time After: 0.00754 seconds
Time Taken: 0.00303 seconds
Time Before: 0.00363 seconds
Time After: 0.01243 seconds
Time Taken: 0.00880 seconds
Time Before: 0.01495 seconds
Time After: 0.01517 seconds
Time Before: 0.01685 seconds
Time After: 0.01820 seconds
Time Taken: 0.00135 seconds
Time Before: 0.01415 seconds
Time After: 0.01839 seconds
Time Taken: 0.00424 seconds
Time Before: 0.02361 seconds
Time After: 0.02375 seconds
REPLACE INTO datastore
(title, data, unserialize)
VALUES
('loadcache', 'a:2:{s:7:\"loadavg\";s:6:\"17.80,\";s:9:\"lastcheck\";i:1789107468;}', 1)Time Before: 0.03043 seconds
Time After: 0.03103 seconds
Time Taken: 0.00060 seconds
Memory Before: 3,439.656 KB
Memory After: 3,439.906 KB
Memory Used: 0.250 KB
Time Before: 0.03364 seconds
Time After: 0.03540 seconds
Time Taken: 0.00175 seconds
Memory Before: 3,526.469 KB
Memory After: 3,527.063 KB
Time Before: 0.04031 seconds
Time After: 0.04047 seconds
Memory Before: 4,164.406 KB
Memory After: 4,164.836 KB
Time Before: 0.04286 seconds
Time After: 0.04430 seconds
Memory Before: 4,446.055 KB
Memory After: 4,447.742 KB
UPDATE session SET lastactivity = 1789107468, location = '/forums/private.php?do=newpm&explain=1&u=130324', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.05833 seconds
Time After: 0.05868 seconds
Memory Before: 4,920.063 KB
Memory After: 4,920.273 KB
