Time Before: 0.02088 seconds
Time After: 0.02970 seconds
Time Taken: 0.00882 seconds
Time Before: 0.02979 seconds
Time After: 0.03055 seconds
Time Taken: 0.00076 seconds
Time Before: 0.03082 seconds
Time After: 0.03098 seconds
Time Before: 0.03179 seconds
Time After: 0.03410 seconds
Time Taken: 0.00231 seconds
Time Before: 0.03105 seconds
Time After: 0.03839 seconds
Time Taken: 0.00734 seconds
Time Before: 0.04881 seconds
Time After: 0.04935 seconds
Time Taken: 0.00055 seconds
Time Before: 0.05203 seconds
Time After: 0.05322 seconds
Time Before: 0.04776 seconds
Time After: 0.05342 seconds
Time Taken: 0.00566 seconds
Time Before: 0.08764 seconds
Time After: 0.08779 seconds
Time Before: 0.10918 seconds
Time After: 0.11042 seconds
Time Before: 0.11899 seconds
Time After: 0.11916 seconds
Time Before: 0.12159 seconds
Time After: 0.12303 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=130355' WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.14114 seconds
Time After: 0.14140 seconds
Memory Before: 4,911.586 KB
Memory After: 4,911.828 KB
