Time Before: 0.00188 seconds
Time After: 0.00245 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00252 seconds
Time After: 0.00298 seconds
Time Before: 0.00320 seconds
Time After: 0.00336 seconds
Time Before: 0.00415 seconds
Time After: 0.00675 seconds
Time Taken: 0.00260 seconds
Time Before: 0.00341 seconds
Time After: 0.01016 seconds
Time Taken: 0.00675 seconds
Time Before: 0.01203 seconds
Time After: 0.01228 seconds
Time Before: 0.01486 seconds
Time After: 0.01620 seconds
Time Taken: 0.00133 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01141 seconds
Time After: 0.01637 seconds
Time Taken: 0.00496 seconds
Memory After: 2,261.820 KB
Time Before: 0.02143 seconds
Time After: 0.02162 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.69499 seconds
Time After: 0.69666 seconds
Time Taken: 0.00167 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.70353 seconds
Time After: 0.70369 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.70676 seconds
Time After: 0.70831 seconds
Time Taken: 0.00155 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1788935979, location = '/forums/private.php?do=newpm&explain=1&u=130360', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.72447 seconds
Time After: 0.72472 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
