Time Before: 0.00252 seconds
Time After: 0.00345 seconds
Time Taken: 0.00093 seconds
Time Before: 0.00352 seconds
Time After: 0.00501 seconds
Time Before: 0.00528 seconds
Time After: 0.00546 seconds
Time Before: 0.00630 seconds
Time After: 0.00886 seconds
Time Taken: 0.00255 seconds
Time Before: 0.00555 seconds
Time After: 0.01453 seconds
Time Taken: 0.00899 seconds
Time Before: 0.01696 seconds
Time After: 0.01718 seconds
Time Before: 0.02042 seconds
Time After: 0.02164 seconds
Time Before: 0.01621 seconds
Time After: 0.02190 seconds
Time Taken: 0.00570 seconds
Time Before: 0.02968 seconds
Time After: 0.02989 seconds
Time Before: 0.05537 seconds
Time After: 0.05676 seconds
Time Taken: 0.00140 seconds
Time Before: 0.06126 seconds
Time After: 0.06142 seconds
Time Before: 0.06471 seconds
Time After: 0.06621 seconds
UPDATE session SET lastactivity = 1783059569, location = '/forums/private.php?do=newpm&explain=1&u=130437', badlocation = 1 WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.08657 seconds
Time After: 0.08684 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
