Time Before: 0.00176 seconds
Time After: 0.00223 seconds
Time Before: 0.00231 seconds
Time After: 0.00274 seconds
Time Before: 0.00299 seconds
Time After: 0.00314 seconds
Time Before: 0.00395 seconds
Time After: 0.00598 seconds
Time Taken: 0.00203 seconds
Time Before: 0.00321 seconds
Time After: 0.00937 seconds
Time Taken: 0.00616 seconds
Time Before: 0.01129 seconds
Time After: 0.01165 seconds
Time Before: 0.01308 seconds
Time After: 0.01430 seconds
Time Before: 0.01071 seconds
Time After: 0.01447 seconds
Time Taken: 0.00376 seconds
Time Before: 0.01951 seconds
Time After: 0.01963 seconds
Time Before: 0.02144 seconds
Time After: 0.02268 seconds
Time Before: 0.02655 seconds
Time After: 0.02673 seconds
Time Before: 0.02931 seconds
Time After: 0.03078 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=130468' WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.04562 seconds
Time After: 0.04598 seconds
