Time Before: 0.00148 seconds
Time After: 0.00194 seconds
Time Before: 0.00201 seconds
Time After: 0.00251 seconds
Time Before: 0.00273 seconds
Time After: 0.00284 seconds
Time Before: 0.00350 seconds
Time After: 0.00625 seconds
Time Taken: 0.00275 seconds
Time Before: 0.00289 seconds
Time After: 0.00966 seconds
Time Taken: 0.00678 seconds
Time Before: 0.01145 seconds
Time After: 0.01173 seconds
Time Before: 0.01403 seconds
Time After: 0.01532 seconds
Time Before: 0.01084 seconds
Time After: 0.01549 seconds
Time Taken: 0.00465 seconds
Time Before: 0.02076 seconds
Time After: 0.02100 seconds
Time Before: 0.02283 seconds
Time After: 0.02404 seconds
End call of global.php: 0.025771856307983
Time Before: 0.02701 seconds
Time After: 0.02724 seconds
Time Before: 0.02938 seconds
Time After: 0.03082 seconds
SET lastactivity = 1783181864, location = '/forums/private.php?do=newpm&explain=1&u=130485', badlocation = 1
Time Before: 0.04339 seconds
Time After: 0.04367 seconds
Memory Before: 4,289.344 KB
Memory After: 4,289.555 KB
Page generated in 0.042419910430908 seconds with 9 queries, spending 0.0083217620849609 doing MySQL queries and 0.034098148345947 doing PHP things.
