Time Before: 0.00154 seconds
Time After: 0.00204 seconds
Time Before: 0.00211 seconds
Time After: 0.00247 seconds
Time Before: 0.00272 seconds
Time After: 0.00286 seconds
Time Before: 0.00374 seconds
Time After: 0.00642 seconds
Time Taken: 0.00268 seconds
Time Before: 0.00295 seconds
Time After: 0.01204 seconds
Time Taken: 0.00909 seconds
Time Before: 0.01417 seconds
Time After: 0.01446 seconds
Time Before: 0.01709 seconds
Time After: 0.01839 seconds
Time Before: 0.01347 seconds
Time After: 0.01857 seconds
Time Taken: 0.00511 seconds
Time Before: 0.02381 seconds
Time After: 0.02400 seconds
Time Before: 0.02690 seconds
Time After: 0.02816 seconds
Time Before: 0.03222 seconds
Time After: 0.03235 seconds
Time Before: 0.03522 seconds
Time After: 0.03665 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=130568', badlocation = 1 WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.04934 seconds
Time After: 0.04970 seconds
Memory Before: 4,288.977 KB
Memory After: 4,289.203 KB
