Time Before: 0.03063 seconds
Time After: 0.03830 seconds
Time Taken: 0.00767 seconds
Time Before: 0.03841 seconds
Time After: 0.03888 seconds
Time Before: 0.03916 seconds
Time After: 0.03935 seconds
Time Before: 0.04013 seconds
Time After: 0.04273 seconds
Time Taken: 0.00260 seconds
Time Before: 0.03941 seconds
Time After: 0.04718 seconds
Time Taken: 0.00777 seconds
Time Before: 0.05503 seconds
Time After: 0.05531 seconds
Time Before: 0.05780 seconds
Time After: 0.05929 seconds
Time Before: 0.05433 seconds
Time After: 0.05951 seconds
Time Taken: 0.00519 seconds
Time Before: 0.10780 seconds
Time After: 0.10799 seconds
Time Before: 0.12449 seconds
Time After: 0.12711 seconds
Time Taken: 0.00263 seconds
Time Before: 0.13898 seconds
Time After: 0.13917 seconds
Time Before: 0.14204 seconds
Time After: 0.14358 seconds
Time Taken: 0.00154 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=130601', badlocation = 1 WHERE sessionhash = 'b910b85238c3231bdc641e11d90490dd'
Time Before: 0.16225 seconds
Time After: 0.16254 seconds
