Time Before: 0.00155 seconds
Time After: 0.00217 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00224 seconds
Time After: 0.00274 seconds
Time Before: 0.00302 seconds
Time After: 0.00320 seconds
Time Before: 0.00407 seconds
Time After: 0.00688 seconds
Time Taken: 0.00281 seconds
Time Before: 0.00328 seconds
Time After: 0.01200 seconds
Time Taken: 0.00871 seconds
Time Before: 0.01413 seconds
Time After: 0.01450 seconds
Time Before: 0.01691 seconds
Time After: 0.01812 seconds
Time Before: 0.01343 seconds
Time After: 0.01830 seconds
Time Taken: 0.00487 seconds
Time Before: 0.02341 seconds
Time After: 0.02358 seconds
Time Before: 0.02592 seconds
Time After: 0.02725 seconds
Time Taken: 0.00133 seconds
End call of global.php: 0.029950141906738
Time Before: 0.03241 seconds
Time After: 0.03262 seconds
Time Before: 0.03458 seconds
Time After: 0.03608 seconds
Time Taken: 0.00150 seconds
SET lastactivity = 1789106347, location = '/forums/private.php?do=newpm&explain=1&u=130690', badlocation = 1
Time Before: 0.04879 seconds
Time After: 0.04916 seconds
Page generated in 0.047839164733887 seconds with 9 queries, spending 0.0086524486541748 doing MySQL queries and 0.039186716079712 doing PHP things.
