Time Before: 0.00821 seconds
Time After: 0.01000 seconds
Time Taken: 0.00179 seconds
Time Before: 0.01007 seconds
Time After: 0.01058 seconds
Time Before: 0.01090 seconds
Time After: 0.01107 seconds
Time Before: 0.01193 seconds
Time After: 0.01479 seconds
Time Taken: 0.00286 seconds
Time Before: 0.01114 seconds
Time After: 0.01851 seconds
Time Taken: 0.00736 seconds
Time Before: 0.02439 seconds
Time After: 0.02488 seconds
Time Before: 0.02632 seconds
Time After: 0.02769 seconds
Time Taken: 0.00137 seconds
Time Before: 0.02374 seconds
Time After: 0.02788 seconds
Time Taken: 0.00415 seconds
Time Before: 0.05378 seconds
Time After: 0.05400 seconds
Time Before: 0.06649 seconds
Time After: 0.06779 seconds
End call of global.php: 0.069507122039795
Time Before: 0.07437 seconds
Time After: 0.07459 seconds
Time Before: 0.07679 seconds
Time After: 0.07827 seconds
SET lastactivity = 1783066723, location = '/forums/private.php?do=newpm&explain=1&u=130700'
Time Before: 0.09546 seconds
Time After: 0.09577 seconds
Page generated in 0.094515085220337 seconds with 9 queries, spending 0.0089406967163086 doing MySQL queries and 0.085574388504028 doing PHP things.
