Time Before: 0.00136 seconds
Time After: 0.00183 seconds
Time Before: 0.00190 seconds
Time After: 0.00230 seconds
Time Before: 0.00249 seconds
Time After: 0.00267 seconds
Time Before: 0.00332 seconds
Time After: 0.00565 seconds
Time Taken: 0.00233 seconds
Time Before: 0.00272 seconds
Time After: 0.00970 seconds
Time Taken: 0.00698 seconds
Time Before: 0.01261 seconds
Time After: 0.01291 seconds
Time Before: 0.01490 seconds
Time After: 0.01611 seconds
Time Before: 0.01144 seconds
Time After: 0.01637 seconds
Time Taken: 0.00493 seconds
Time Before: 0.02264 seconds
Time After: 0.02280 seconds
Time Before: 0.02452 seconds
Time After: 0.02580 seconds
End call of global.php: 0.027651786804199
Time Before: 0.02881 seconds
Time After: 0.02896 seconds
Time Before: 0.03184 seconds
Time After: 0.03344 seconds
Time Taken: 0.00160 seconds
SET lastactivity = 1780617205, location = '/forums/private.php?do=newpm&explain=1&u=13071'
WHERE sessionhash = '295cc732df117534f65c11ae631a16f6'
Time Before: 0.04809 seconds
Time After: 0.04840 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.047096014022827 seconds with 9 queries, spending 0.0079214572906494 doing MySQL queries and 0.039174556732178 doing PHP things.
