Time Before: 0.02584 seconds
Time After: 0.03302 seconds
Time Taken: 0.00718 seconds
Time Before: 0.03310 seconds
Time After: 0.03349 seconds
Time Before: 0.03371 seconds
Time After: 0.03382 seconds
Time Before: 0.03458 seconds
Time After: 0.03721 seconds
Time Taken: 0.00263 seconds
Time Before: 0.03389 seconds
Time After: 0.04229 seconds
Time Taken: 0.00840 seconds
Time Before: 0.05214 seconds
Time After: 0.05267 seconds
Time Taken: 0.00053 seconds
Time Before: 0.05442 seconds
Time After: 0.05557 seconds
Time Taken: 0.00116 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.05134 seconds
Time After: 0.05584 seconds
Time Taken: 0.00450 seconds
Memory After: 2,261.703 KB
Time Before: 0.08647 seconds
Time After: 0.08662 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.10894 seconds
Time After: 0.11082 seconds
Time Taken: 0.00188 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.11940 seconds
Time After: 0.11955 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.12204 seconds
Time After: 0.12345 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=130752', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.14184 seconds
Time After: 0.14224 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
