Time Before: 0.00188 seconds
Time After: 0.00240 seconds
Time Before: 0.00247 seconds
Time After: 0.00302 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00324 seconds
Time After: 0.00337 seconds
Time Before: 0.00418 seconds
Time After: 0.00716 seconds
Time Taken: 0.00299 seconds
Time Before: 0.00342 seconds
Time After: 0.01060 seconds
Time Taken: 0.00718 seconds
Time Before: 0.01249 seconds
Time After: 0.01291 seconds
Time Before: 0.01606 seconds
Time After: 0.01723 seconds
Time Taken: 0.00116 seconds
Time Before: 0.01187 seconds
Time After: 0.01740 seconds
Time Taken: 0.00553 seconds
Time Before: 0.02241 seconds
Time After: 0.02253 seconds
Time Before: 0.02448 seconds
Time After: 0.02569 seconds
End call of global.php: 0.027295112609863
Time Before: 0.02878 seconds
Time After: 0.02893 seconds
Time Before: 0.03101 seconds
Time After: 0.03244 seconds
SET lastactivity = 1785404330, location = '/forums/private.php?do=newpm&explain=1&u=130761'
Time Before: 0.04509 seconds
Time After: 0.04546 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
Page generated in 0.044151067733765 seconds with 9 queries, spending 0.008516788482666 doing MySQL queries and 0.035634279251099 doing PHP things.
