Time Before: 0.00147 seconds
Time After: 0.00197 seconds
Time Before: 0.00204 seconds
Time After: 0.00251 seconds
Time Before: 0.00272 seconds
Time After: 0.00290 seconds
Time Before: 0.00373 seconds
Time After: 0.00619 seconds
Time Taken: 0.00246 seconds
Time Before: 0.00298 seconds
Time After: 0.01023 seconds
Time Taken: 0.00725 seconds
Time Before: 0.01207 seconds
Time After: 0.01243 seconds
Time Before: 0.01385 seconds
Time After: 0.01516 seconds
Time Taken: 0.00131 seconds
Time Before: 0.01146 seconds
Time After: 0.01540 seconds
Time Taken: 0.00394 seconds
Time Before: 0.02196 seconds
Time After: 0.02213 seconds
Time Before: 0.02594 seconds
Time After: 0.02718 seconds
Time Before: 0.03177 seconds
Time After: 0.03195 seconds
Time Before: 0.03456 seconds
Time After: 0.03617 seconds
Time Taken: 0.00161 seconds
UPDATE session SET lastactivity = 1784806567, location = '/forums/private.php?do=newpm&explain=1&u=130779' WHERE sessionhash = '6d76899e3772524375a2c635be997117'
Time Before: 0.05104 seconds
Time After: 0.05131 seconds
