Time Before: 0.00216 seconds
Time After: 0.00276 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00286 seconds
Time After: 0.00350 seconds
Time Taken: 0.00064 seconds
Time Before: 0.00375 seconds
Time After: 0.00387 seconds
Time Before: 0.00461 seconds
Time After: 0.00766 seconds
Time Taken: 0.00305 seconds
Time Before: 0.00392 seconds
Time After: 0.01111 seconds
Time Taken: 0.00719 seconds
Time Before: 0.01312 seconds
Time After: 0.01340 seconds
Time Before: 0.01506 seconds
Time After: 0.01626 seconds
Time Before: 0.01245 seconds
Time After: 0.01643 seconds
Time Taken: 0.00398 seconds
Time Before: 0.02149 seconds
Time After: 0.02165 seconds
Time Before: 0.02372 seconds
Time After: 0.02530 seconds
Time Taken: 0.00158 seconds
Time Before: 0.02940 seconds
Time After: 0.02969 seconds
Time Before: 0.03279 seconds
Time After: 0.03462 seconds
Time Taken: 0.00183 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=130926', badlocation = 1 WHERE sessionhash = '708f3049c6f4aeb346a0a4658c824d43'
Time Before: 0.04914 seconds
Time After: 0.04948 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
