Time Before: 0.00790 seconds
Time After: 0.00982 seconds
Time Taken: 0.00192 seconds
Time Before: 0.00991 seconds
Time After: 0.01114 seconds
Time Before: 0.01138 seconds
Time After: 0.01156 seconds
Time Before: 0.01240 seconds
Time After: 0.01461 seconds
Time Taken: 0.00221 seconds
Time Before: 0.01163 seconds
Time After: 0.01941 seconds
Time Taken: 0.00777 seconds
Time Before: 0.02406 seconds
Time After: 0.02450 seconds
Time Before: 0.02763 seconds
Time After: 0.02885 seconds
Time Before: 0.02330 seconds
Time After: 0.02910 seconds
Time Taken: 0.00580 seconds
Time Before: 0.04373 seconds
Time After: 0.04389 seconds
Time Before: 0.05481 seconds
Time After: 0.05671 seconds
Time Taken: 0.00189 seconds
End call of global.php: 0.058944940567017
Time Before: 0.06308 seconds
Time After: 0.06325 seconds
Time Before: 0.06602 seconds
Time After: 0.06820 seconds
Time Taken: 0.00218 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=13096'
Time Before: 0.08664 seconds
Time After: 0.08706 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.085587978363037 seconds with 9 queries, spending 0.010122299194336 doing MySQL queries and 0.075465679168701 doing PHP things.
