Time Before: 0.01828 seconds
Time After: 0.02226 seconds
Time Taken: 0.00398 seconds
Time Before: 0.02237 seconds
Time After: 0.02351 seconds
Time Taken: 0.00114 seconds
Time Before: 0.02375 seconds
Time After: 0.02389 seconds
Time Before: 0.02467 seconds
Time After: 0.02681 seconds
Time Taken: 0.00214 seconds
Time Before: 0.02396 seconds
Time After: 0.03116 seconds
Time Taken: 0.00720 seconds
Time Before: 0.03589 seconds
Time After: 0.03631 seconds
Time Before: 0.03781 seconds
Time After: 0.03902 seconds
Time Before: 0.03503 seconds
Time After: 0.03923 seconds
Time Taken: 0.00420 seconds
Time Before: 0.06922 seconds
Time After: 0.06936 seconds
Time Before: 0.07899 seconds
Time After: 0.08021 seconds
End call of global.php: 0.082237005233765
Time Before: 0.08717 seconds
Time After: 0.08733 seconds
Time Before: 0.09057 seconds
Time After: 0.09205 seconds
SET lastactivity = 1783074890, location = '/forums/private.php?do=newpm&explain=1&u=130963'
Time Before: 0.11060 seconds
Time After: 0.11099 seconds
Page generated in 0.10949492454529 seconds with 9 queries, spending 0.0084314346313477 doing MySQL queries and 0.10106348991394 doing PHP things.
