Time Before: 0.00167 seconds
Time After: 0.00221 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00229 seconds
Time After: 0.00270 seconds
Time Before: 0.00289 seconds
Time After: 0.00303 seconds
Time Before: 0.00394 seconds
Time After: 0.00631 seconds
Time Taken: 0.00237 seconds
Time Before: 0.00307 seconds
Time After: 0.01000 seconds
Time Taken: 0.00693 seconds
Time Before: 0.01212 seconds
Time After: 0.01253 seconds
Time Before: 0.01402 seconds
Time After: 0.01521 seconds
Time Taken: 0.00118 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01145 seconds
Time After: 0.01539 seconds
Time Taken: 0.00394 seconds
Memory After: 2,261.703 KB
Time Before: 0.02039 seconds
Time After: 0.02051 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02241 seconds
Time After: 0.02373 seconds
Time Taken: 0.00133 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.02674 seconds
Time After: 0.02692 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.02895 seconds
Time After: 0.03036 seconds
Time Taken: 0.00140 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=131025' WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.04342 seconds
Time After: 0.04366 seconds
Memory Before: 4,288.000 KB
Memory After: 4,288.242 KB
