Time Before: 0.01375 seconds
Time After: 0.01791 seconds
Time Taken: 0.00416 seconds
Time Before: 0.01800 seconds
Time After: 0.01842 seconds
Time Before: 0.01865 seconds
Time After: 0.01878 seconds
Time Before: 0.01960 seconds
Time After: 0.02203 seconds
Time Taken: 0.00243 seconds
Time Before: 0.01884 seconds
Time After: 0.02603 seconds
Time Taken: 0.00718 seconds
Time Before: 0.03120 seconds
Time After: 0.03159 seconds
Time Before: 0.03413 seconds
Time After: 0.03532 seconds
Time Before: 0.03051 seconds
Time After: 0.03553 seconds
Time Taken: 0.00502 seconds
Time Before: 0.05188 seconds
Time After: 0.05201 seconds
Time Before: 0.06133 seconds
Time After: 0.06293 seconds
Time Taken: 0.00160 seconds
End call of global.php: 0.065280914306641
Time Before: 0.06937 seconds
Time After: 0.06953 seconds
Time Before: 0.07174 seconds
Time After: 0.07318 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=131034'
Time Before: 0.08693 seconds
Time After: 0.08718 seconds
Page generated in 0.086025953292847 seconds with 9 queries, spending 0.008143424987793 doing MySQL queries and 0.077882528305054 doing PHP things.
