Time Before: 0.00166 seconds
Time After: 0.00223 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00230 seconds
Time After: 0.00268 seconds
Time Before: 0.00294 seconds
Time After: 0.00308 seconds
Time Before: 0.00390 seconds
Time After: 0.00604 seconds
Time Taken: 0.00215 seconds
Time Before: 0.00316 seconds
Time After: 0.01075 seconds
Time Taken: 0.00759 seconds
Time Before: 0.01269 seconds
Time After: 0.01311 seconds
Time Before: 0.01556 seconds
Time After: 0.01677 seconds
Time Before: 0.01205 seconds
Time After: 0.01703 seconds
Time Taken: 0.00498 seconds
Time Before: 0.02531 seconds
Time After: 0.02544 seconds
Time Before: 0.02793 seconds
Time After: 0.02914 seconds
End call of global.php: 0.030907869338989
Time Before: 0.03215 seconds
Time After: 0.03226 seconds
Time Before: 0.03430 seconds
Time After: 0.03572 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=13104', badlocation = 1
Time Before: 0.04854 seconds
Time After: 0.04882 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.047567844390869 seconds with 9 queries, spending 0.007462739944458 doing MySQL queries and 0.040105104446411 doing PHP things.
