Time Before: 0.00142 seconds
Time After: 0.00191 seconds
Time Before: 0.00198 seconds
Time After: 0.00239 seconds
Time Before: 0.00269 seconds
Time After: 0.00284 seconds
Time Before: 0.00374 seconds
Time After: 0.00649 seconds
Time Taken: 0.00275 seconds
Time Before: 0.00292 seconds
Time After: 0.00998 seconds
Time Taken: 0.00706 seconds
Time Before: 0.01254 seconds
Time After: 0.01290 seconds
Time Before: 0.01419 seconds
Time After: 0.01543 seconds
Time Before: 0.01191 seconds
Time After: 0.01561 seconds
Time Taken: 0.00370 seconds
Time Before: 0.02084 seconds
Time After: 0.02099 seconds
Time Before: 0.02354 seconds
Time After: 0.02477 seconds
End call of global.php: 0.026482105255127
Time Before: 0.02774 seconds
Time After: 0.02789 seconds
Time Before: 0.03004 seconds
Time After: 0.03223 seconds
Time Taken: 0.00219 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=131041'
Time Before: 0.04618 seconds
Time After: 0.04680 seconds
Time Taken: 0.00062 seconds
Page generated in 0.045214176177979 seconds with 9 queries, spending 0.009253978729248 doing MySQL queries and 0.03596019744873 doing PHP things.
