Time Before: 0.00315 seconds
Time After: 0.00368 seconds
Time Before: 0.00376 seconds
Time After: 0.00424 seconds
Time Before: 0.00444 seconds
Time After: 0.00458 seconds
Time Before: 0.00528 seconds
Time After: 0.00758 seconds
Time Taken: 0.00231 seconds
Time Before: 0.00465 seconds
Time After: 0.01108 seconds
Time Taken: 0.00643 seconds
Time Before: 0.01280 seconds
Time After: 0.01310 seconds
Time Before: 0.01575 seconds
Time After: 0.01699 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01230 seconds
Time After: 0.01717 seconds
Time Taken: 0.00487 seconds
Memory After: 2,261.703 KB
Time Before: 0.02248 seconds
Time After: 0.02260 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02482 seconds
Time After: 0.02606 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.027992010116577
Time Before: 0.02944 seconds
Time After: 0.02975 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03175 seconds
Time After: 0.03327 seconds
Time Taken: 0.00152 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=131044', badlocation = 1
Time Before: 0.04548 seconds
Time After: 0.04586 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
Page generated in 0.044579982757568 seconds with 9 queries, spending 0.0080528259277344 doing MySQL queries and 0.036527156829834 doing PHP things.
