Time Before: 0.02849 seconds
Time After: 0.03331 seconds
Time Taken: 0.00482 seconds
Memory Before: 532.883 KB
Memory After: 558.000 KB
Time Before: 0.03340 seconds
Time After: 0.03387 seconds
Memory Before: 557.938 KB
Memory After: 558.945 KB
Time Before: 0.03416 seconds
Time After: 0.03434 seconds
Memory Before: 559.500 KB
Memory After: 560.023 KB
Time Before: 0.03505 seconds
Time After: 0.03733 seconds
Time Taken: 0.00227 seconds
Memory Before: 562.625 KB
Memory After: 563.547 KB
Time Before: 0.03439 seconds
Time After: 0.04085 seconds
Time Taken: 0.00646 seconds
Memory Before: 559.273 KB
Memory After: 1,640.320 KB
Memory Used: 1,081.047 KB
Time Before: 0.05152 seconds
Time After: 0.05205 seconds
Memory Before: 2,135.250 KB
Memory After: 2,135.867 KB
Time Before: 0.05445 seconds
Time After: 0.05575 seconds
Memory Before: 2,147.313 KB
Memory After: 2,147.172 KB
Time Before: 0.05084 seconds
Time After: 0.05599 seconds
Time Taken: 0.00515 seconds
Memory Before: 2,127.430 KB
Memory After: 2,260.523 KB
Memory Used: 133.094 KB
Time Before: 0.11701 seconds
Time After: 0.11717 seconds
Memory Before: 2,814.047 KB
Memory After: 2,814.563 KB
Time Before: 0.14093 seconds
Time After: 0.14223 seconds
Memory Before: 2,902.336 KB
Memory After: 2,902.930 KB
Time Before: 0.15449 seconds
Time After: 0.15482 seconds
Memory Before: 3,539.156 KB
Memory After: 3,539.586 KB
Time Before: 0.15769 seconds
Time After: 0.15917 seconds
Memory Before: 3,820.688 KB
Memory After: 3,822.375 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=131080', badlocation = 1 WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.18221 seconds
Time After: 0.18247 seconds
Memory Before: 4,299.023 KB
Memory After: 4,299.250 KB
