Time Before: 0.02820 seconds
Time After: 0.03739 seconds
Time Taken: 0.00919 seconds
Memory Before: 534.492 KB
Memory After: 559.609 KB
Time Before: 0.03747 seconds
Time After: 0.03794 seconds
Memory Before: 559.547 KB
Memory After: 560.555 KB
Time Before: 0.03820 seconds
Time After: 0.03834 seconds
Memory Before: 561.109 KB
Memory After: 561.633 KB
Time Before: 0.03908 seconds
Time After: 0.04191 seconds
Time Taken: 0.00283 seconds
Memory Before: 564.234 KB
Memory After: 565.156 KB
Time Before: 0.03839 seconds
Time After: 0.04610 seconds
Time Taken: 0.00771 seconds
Memory Before: 560.883 KB
Memory After: 1,641.883 KB
Memory Used: 1,081.000 KB
Time Before: 0.05654 seconds
Time After: 0.05693 seconds
Memory Before: 2,136.727 KB
Memory After: 2,137.344 KB
Time Before: 0.05969 seconds
Time After: 0.06093 seconds
Memory Before: 2,148.789 KB
Memory After: 2,148.648 KB
Time Before: 0.05581 seconds
Time After: 0.06120 seconds
Time Taken: 0.00539 seconds
Memory Before: 2,128.906 KB
Memory After: 2,261.672 KB
Time Before: 0.10657 seconds
Time After: 0.10674 seconds
Memory Before: 2,815.242 KB
Memory After: 2,815.758 KB
Time Before: 0.12887 seconds
Time After: 0.13022 seconds
Time Taken: 0.00135 seconds
Memory Before: 2,903.539 KB
Memory After: 2,904.133 KB
Time Before: 0.14053 seconds
Time After: 0.14072 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.14284 seconds
Time After: 0.14428 seconds
Memory Before: 3,821.875 KB
Memory After: 3,823.563 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=131092' WHERE sessionhash = '708f3049c6f4aeb346a0a4658c824d43'
Time Before: 0.16141 seconds
Time After: 0.16167 seconds
Memory Before: 4,296.258 KB
Memory After: 4,296.500 KB
