Time Before: 0.02582 seconds
Time After: 0.03734 seconds
Time Taken: 0.01152 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.03746 seconds
Time After: 0.03796 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.03830 seconds
Time After: 0.03846 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.03920 seconds
Time After: 0.04158 seconds
Time Taken: 0.00239 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.03853 seconds
Time After: 0.04603 seconds
Time Taken: 0.00750 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.05619 seconds
Time After: 0.05662 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.05920 seconds
Time After: 0.06063 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.05552 seconds
Time After: 0.06089 seconds
Time Taken: 0.00538 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.10873 seconds
Time After: 0.10887 seconds
Memory Before: 3,655.820 KB
Memory After: 3,656.336 KB
Time Before: 0.16667 seconds
Time After: 0.16860 seconds
Time Taken: 0.00194 seconds
Memory Before: 4,133.383 KB
Memory After: 4,133.977 KB
End call of global.php: 0.17087197303772
Time Before: 0.20115 seconds
Time After: 0.20135 seconds
Memory Before: 5,197.555 KB
Memory After: 5,325.898 KB
Time Before: 0.20532 seconds
Time After: 0.20678 seconds
Memory Before: 5,481.250 KB
Memory After: 5,610.852 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=131178'
WHERE sessionhash = '600503b925d08d481e162d46884ab830'
Time Before: 0.23817 seconds
Time After: 0.23844 seconds
Memory Before: 5,998.352 KB
Memory After: 5,998.594 KB
Page generated in 0.23708009719849 seconds with 9 queries, spending 0.0089209079742432 doing MySQL queries and 0.22815918922424 doing PHP things.
