Time Before: 0.00135 seconds
Time After: 0.00178 seconds
Time Before: 0.00184 seconds
Time After: 0.00239 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00261 seconds
Time After: 0.00274 seconds
Time Before: 0.00335 seconds
Time After: 0.00682 seconds
Time Taken: 0.00347 seconds
Time Before: 0.00279 seconds
Time After: 0.01014 seconds
Time Taken: 0.00735 seconds
Time Before: 0.01216 seconds
Time After: 0.01259 seconds
Time Before: 0.01495 seconds
Time After: 0.01616 seconds
Time Before: 0.01151 seconds
Time After: 0.01636 seconds
Time Taken: 0.00485 seconds
Time Before: 0.02171 seconds
Time After: 0.02189 seconds
Time Before: 0.02417 seconds
Time After: 0.02540 seconds
End call of global.php: 0.027111053466797
Time Before: 0.02831 seconds
Time After: 0.02847 seconds
Time Before: 0.03041 seconds
Time After: 0.03187 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=131185', badlocation = 1
Time Before: 0.04456 seconds
Time After: 0.04497 seconds
Memory Before: 4,911.867 KB
Memory After: 4,912.094 KB
Page generated in 0.043667078018188 seconds with 9 queries, spending 0.0092563629150391 doing MySQL queries and 0.034410715103149 doing PHP things.
