Time Before: 0.00180 seconds
Time After: 0.00252 seconds
Time Taken: 0.00072 seconds
Time Before: 0.00259 seconds
Time After: 0.00297 seconds
Time Before: 0.00323 seconds
Time After: 0.00336 seconds
Time Before: 0.00423 seconds
Time After: 0.00722 seconds
Time Taken: 0.00299 seconds
Time Before: 0.00344 seconds
Time After: 0.01149 seconds
Time Taken: 0.00806 seconds
Time Before: 0.01341 seconds
Time After: 0.01367 seconds
Time Before: 0.01660 seconds
Time After: 0.01779 seconds
Time Before: 0.01278 seconds
Time After: 0.01802 seconds
Time Taken: 0.00525 seconds
Time Before: 0.02463 seconds
Time After: 0.02476 seconds
Time Before: 0.02717 seconds
Time After: 0.02843 seconds
Time Before: 0.03284 seconds
Time After: 0.03299 seconds
Time Before: 0.03565 seconds
Time After: 0.03708 seconds
UPDATE session SET lastactivity = 1782880000, location = '/forums/private.php?do=newpm&explain=1&u=131231', badlocation = 1 WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.05083 seconds
Time After: 0.05110 seconds
