Time Before: 0.00150 seconds
Time After: 0.00206 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00213 seconds
Time After: 0.00257 seconds
Time Before: 0.00282 seconds
Time After: 0.00296 seconds
Time Before: 0.00389 seconds
Time After: 0.00662 seconds
Time Taken: 0.00273 seconds
Time Before: 0.00304 seconds
Time After: 0.01050 seconds
Time Taken: 0.00746 seconds
Time Before: 0.01232 seconds
Time After: 0.01276 seconds
Time Before: 0.01610 seconds
Time After: 0.01737 seconds
Time Before: 0.01169 seconds
Time After: 0.01762 seconds
Time Taken: 0.00593 seconds
Time Before: 0.02484 seconds
Time After: 0.02533 seconds
Time Before: 0.02767 seconds
Time After: 0.02894 seconds
Time Before: 0.03252 seconds
Time After: 0.03284 seconds
Time Before: 0.03575 seconds
Time After: 0.03718 seconds
UPDATE session SET lastactivity = 1789058816, location = '/forums/private.php?do=newpm&explain=1&u=131255' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.05286 seconds
Time After: 0.05323 seconds
