Time Before: 0.03997 seconds
Time After: 0.04880 seconds
Time Taken: 0.00883 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.04913 seconds
Time After: 0.04958 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.04991 seconds
Time After: 0.05004 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.05079 seconds
Time After: 0.05349 seconds
Time Taken: 0.00269 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.05010 seconds
Time After: 0.05763 seconds
Time Taken: 0.00753 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.06668 seconds
Time After: 0.06714 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.06973 seconds
Time After: 0.07111 seconds
Time Taken: 0.00138 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.06597 seconds
Time After: 0.07133 seconds
Time Taken: 0.00535 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.14721 seconds
Time After: 0.14748 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.25392 seconds
Time After: 0.25519 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
End call of global.php: 0.257483959198
Time Before: 0.30881 seconds
Time After: 0.30899 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.31956 seconds
Time After: 0.32103 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
SET lastactivity = 1772948230, location = '/forums/private.php?do=newpm&explain=1&u=131358', badlocation = 1
WHERE sessionhash = 'a1024cf3a534e5ec94f7248e61d8a1ae'
Time Before: 0.35648 seconds
Time After: 0.35678 seconds
Memory Before: 5,998.219 KB
Memory After: 5,998.430 KB
Page generated in 0.35533499717712 seconds with 9 queries, spending 0.0085992813110352 doing MySQL queries and 0.34673571586609 doing PHP things.
