Time Before: 0.02145 seconds
Time After: 0.02587 seconds
Time Taken: 0.00441 seconds
Time Before: 0.02596 seconds
Time After: 0.02646 seconds
Time Before: 0.02684 seconds
Time After: 0.02699 seconds
Time Before: 0.02780 seconds
Time After: 0.03054 seconds
Time Taken: 0.00274 seconds
Time Before: 0.02709 seconds
Time After: 0.03472 seconds
Time Taken: 0.00763 seconds
Time Before: 0.04139 seconds
Time After: 0.04163 seconds
Time Before: 0.04459 seconds
Time After: 0.04578 seconds
Time Before: 0.04080 seconds
Time After: 0.04597 seconds
Time Taken: 0.00517 seconds
Time Before: 0.08328 seconds
Time After: 0.08349 seconds
Time Before: 0.09776 seconds
Time After: 0.09907 seconds
Time Taken: 0.00131 seconds
End call of global.php: 0.10107898712158
Time Before: 0.10772 seconds
Time After: 0.10788 seconds
Time Before: 0.10998 seconds
Time After: 0.11144 seconds
SET lastactivity = 1783311840, location = '/forums/private.php?do=newpm&explain=1&u=131415', badlocation = 1
WHERE sessionhash = '32502f71822f8bf82bf8c86767d671b1'
Time Before: 0.12624 seconds
Time After: 0.12652 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.12520909309387 seconds with 9 queries, spending 0.0082371234893799 doing MySQL queries and 0.11697196960449 doing PHP things.
