Time Before: 0.00366 seconds
Time After: 0.00510 seconds
Time Before: 0.00517 seconds
Time After: 0.00551 seconds
Time Before: 0.00568 seconds
Time After: 0.00577 seconds
Time Taken: 0.00009 seconds
Time Before: 0.00636 seconds
Time After: 0.00850 seconds
Time Taken: 0.00214 seconds
Time Before: 0.00583 seconds
Time After: 0.01260 seconds
Time Taken: 0.00677 seconds
Time Before: 0.01436 seconds
Time After: 0.01495 seconds
Time Taken: 0.00059 seconds
Time Before: 0.01701 seconds
Time After: 0.01816 seconds
Time Taken: 0.00115 seconds
Time Before: 0.01380 seconds
Time After: 0.01834 seconds
Time Taken: 0.00454 seconds
Time Before: 0.02418 seconds
Time After: 0.02435 seconds
Time Before: 0.02743 seconds
Time After: 0.02937 seconds
Time Taken: 0.00193 seconds
Time Before: 0.03388 seconds
Time After: 0.03405 seconds
Time Before: 0.03690 seconds
Time After: 0.03833 seconds
UPDATE session SET lastactivity = 1788904062, location = '/forums/private.php?do=newpm&explain=1&u=131429' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.05414 seconds
Time After: 0.05443 seconds
