Time Before: 0.01699 seconds
Time After: 0.02064 seconds
Time Taken: 0.00366 seconds
Time Before: 0.02075 seconds
Time After: 0.02121 seconds
Time Before: 0.02147 seconds
Time After: 0.02161 seconds
Time Before: 0.02255 seconds
Time After: 0.02479 seconds
Time Taken: 0.00224 seconds
Time Before: 0.02169 seconds
Time After: 0.02903 seconds
Time Taken: 0.00735 seconds
Time Before: 0.03439 seconds
Time After: 0.03489 seconds
Time Before: 0.03806 seconds
Time After: 0.03931 seconds
Time Before: 0.03355 seconds
Time After: 0.03957 seconds
Time Taken: 0.00602 seconds
Time Before: 0.06240 seconds
Time After: 0.06254 seconds
Time Before: 0.07108 seconds
Time After: 0.07231 seconds
End call of global.php: 0.074694871902466
Time Before: 0.07887 seconds
Time After: 0.07902 seconds
Time Before: 0.08182 seconds
Time After: 0.08324 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=131430'
Time Before: 0.09923 seconds
Time After: 0.09951 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
Page generated in 0.098298072814941 seconds with 9 queries, spending 0.0078144073486328 doing MySQL queries and 0.090483665466309 doing PHP things.
