Time Before: 0.02938 seconds
Time After: 0.03894 seconds
Time Taken: 0.00957 seconds
Time Before: 0.03905 seconds
Time After: 0.03949 seconds
Time Before: 0.03972 seconds
Time After: 0.03990 seconds
Time Before: 0.04062 seconds
Time After: 0.04357 seconds
Time Taken: 0.00295 seconds
Time Before: 0.03995 seconds
Time After: 0.04778 seconds
Time Taken: 0.00783 seconds
Time Before: 0.05670 seconds
Time After: 0.05715 seconds
Time Before: 0.05975 seconds
Time After: 0.06099 seconds
Time Before: 0.05591 seconds
Time After: 0.06120 seconds
Time Taken: 0.00529 seconds
Time Before: 0.10953 seconds
Time After: 0.10969 seconds
Time Before: 0.12961 seconds
Time After: 0.13090 seconds
End call of global.php: 0.1328010559082
Time Before: 0.14578 seconds
Time After: 0.14597 seconds
Time Before: 0.14952 seconds
Time After: 0.15101 seconds
SET lastactivity = 1776710444, location = '/forums/private.php?do=newpm&explain=1&u=131435', badlocation = 1
Time Before: 0.17241 seconds
Time After: 0.17267 seconds
Page generated in 0.17138409614563 seconds with 9 queries, spending 0.0086488723754883 doing MySQL queries and 0.16273522377014 doing PHP things.
