Time Before: 0.00221 seconds
Time After: 0.00282 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00289 seconds
Time After: 0.00329 seconds
Time Before: 0.00348 seconds
Time After: 0.00364 seconds
Time Before: 0.00435 seconds
Time After: 0.00743 seconds
Time Taken: 0.00307 seconds
Time Before: 0.00368 seconds
Time After: 0.01086 seconds
Time Taken: 0.00718 seconds
Time Before: 0.01275 seconds
Time After: 0.01335 seconds
Time Before: 0.01499 seconds
Time After: 0.01630 seconds
Time Taken: 0.00131 seconds
Time Before: 0.01204 seconds
Time After: 0.01647 seconds
Time Taken: 0.00443 seconds
Time Before: 0.02218 seconds
Time After: 0.02239 seconds
Time Before: 0.02459 seconds
Time After: 0.02579 seconds
Time Before: 0.02872 seconds
Time After: 0.02935 seconds
Time Taken: 0.00063 seconds
Time Before: 0.03195 seconds
Time After: 0.03395 seconds
Time Taken: 0.00200 seconds
UPDATE session SET lastactivity = 1788872185, location = '/forums/private.php?do=newpm&explain=1&u=131462', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.04835 seconds
Time After: 0.04869 seconds
