Time Before: 0.00141 seconds
Time After: 0.00233 seconds
Time Taken: 0.00092 seconds
Time Before: 0.00240 seconds
Time After: 0.00285 seconds
Time Before: 0.00305 seconds
Time After: 0.00316 seconds
Time Before: 0.00389 seconds
Time After: 0.00623 seconds
Time Taken: 0.00234 seconds
Time Before: 0.00321 seconds
Time After: 0.00960 seconds
Time Taken: 0.00639 seconds
Time Before: 0.01175 seconds
Time After: 0.01215 seconds
Time Before: 0.01353 seconds
Time After: 0.01495 seconds
Time Before: 0.01111 seconds
Time After: 0.01513 seconds
Time Taken: 0.00402 seconds
Time Before: 0.02033 seconds
Time After: 0.02045 seconds
Time Before: 0.02312 seconds
Time After: 0.02433 seconds
End call of global.php: 0.025967121124268
Time Before: 0.02729 seconds
Time After: 0.02745 seconds
Time Before: 0.02945 seconds
Time After: 0.03087 seconds
SET lastactivity = 1789148405, location = '/forums/private.php?do=newpm&explain=1&u=131475'
Time Before: 0.04510 seconds
Time After: 0.04543 seconds
Memory Before: 4,912.039 KB
Memory After: 4,912.266 KB
Page generated in 0.044197082519531 seconds with 9 queries, spending 0.0079636573791504 doing MySQL queries and 0.036233425140381 doing PHP things.
