Time Before: 0.04282 seconds
Time After: 0.05659 seconds
Time Taken: 0.01378 seconds
Time Before: 0.05672 seconds
Time After: 0.05718 seconds
Time Before: 0.05741 seconds
Time After: 0.05755 seconds
Time Before: 0.05862 seconds
Time After: 0.06124 seconds
Time Taken: 0.00261 seconds
Time Before: 0.05762 seconds
Time After: 0.06513 seconds
Time Taken: 0.00751 seconds
Time Before: 0.07992 seconds
Time After: 0.08037 seconds
Time Before: 0.08277 seconds
Time After: 0.08440 seconds
Time Taken: 0.00163 seconds
Time Before: 0.07919 seconds
Time After: 0.08462 seconds
Time Taken: 0.00543 seconds
Time Before: 0.14569 seconds
Time After: 0.14584 seconds
Time Before: 0.17670 seconds
Time After: 0.17793 seconds
End call of global.php: 0.18003797531128
Time Before: 0.19073 seconds
Time After: 0.19093 seconds
Time Before: 0.19334 seconds
Time After: 0.19476 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=13150', badlocation = 1
WHERE sessionhash = '295cc732df117534f65c11ae631a16f6'
Time Before: 0.21266 seconds
Time After: 0.21303 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
Page generated in 0.2115740776062 seconds with 9 queries, spending 0.0086727142333984 doing MySQL queries and 0.2029013633728 doing PHP things.
