Time Before: 0.00141 seconds
Time After: 0.00189 seconds
Time Before: 0.00196 seconds
Time After: 0.00231 seconds
Time Before: 0.00250 seconds
Time After: 0.00262 seconds
Time Before: 0.00332 seconds
Time After: 0.00546 seconds
Time Taken: 0.00214 seconds
Time Before: 0.00267 seconds
Time After: 0.00887 seconds
Time Taken: 0.00620 seconds
Time Before: 0.01073 seconds
Time After: 0.01095 seconds
Time Before: 0.01337 seconds
Time After: 0.01453 seconds
Time Taken: 0.00116 seconds
Time Before: 0.01013 seconds
Time After: 0.01471 seconds
Time Taken: 0.00458 seconds
Time Before: 0.01978 seconds
Time After: 0.01990 seconds
Time Before: 0.02183 seconds
Time After: 0.02312 seconds
End call of global.php: 0.024816989898682
Time Before: 0.02602 seconds
Time After: 0.02615 seconds
Time Before: 0.02827 seconds
Time After: 0.02976 seconds
SET lastactivity = 1782923181, location = '/forums/private.php?do=newpm&explain=1&u=131500', badlocation = 1
Time Before: 0.04887 seconds
Time After: 0.04916 seconds
Memory Before: 4,912.320 KB
Memory After: 4,912.531 KB
Page generated in 0.047569990158081 seconds with 9 queries, spending 0.0072805881500244 doing MySQL queries and 0.040289402008057 doing PHP things.
